I've just finished building a 5E3 circuit (it's my third, and around my tenth amp in total, so I'm not a complete beginner) and there is only 0.2 VDC across the 250 ohm 6V6 cathode bias resistor. There is sound, but it is like a transistor radio - distorted, quiet, weedy. All the other voltages are very high (458vdc on the plates, 429 on the screens, and proportionally the same down to the preamp). I'm using a Hammond 291BEX, which is rated for Deluxe Reverb as well as Tweed Deluxe,but thought the 5Y3 would bring them down lower than this. I was planning to run 6L6s in it, so the high voltages aren't necessarily a problem (I think?!).
However, the cathode voltage is completely mystifying, and definitely the source of the problem. Here's what I've tried so far...
A different resistor;
Clipping the bypass cap out of the circuit;
Grounding the resistor in lots of different places;
Reflowing all solder joints;
Other valves.
None of these have made any difference.
I am DEFINITELY never building an amp ever again (I don't know why I even started this one - it just gets on my tits) but would very much like to get this working, as I suppose it's going to have to be a keeper. (Also the cab I made looks really nice). So, if anyone can help I will be eternally grateful.
Cheers,
Paul
Photo's?
No voltage means no current flow, so something is not connected, connected to the wrong place or is the wrong value, if you have voltage at the plate pins and screen pins then the list below will likely solve your issue
Check that the 250ohm resistor actually measures 250Ohm
Check that you actually have the 250Ohm resistor grounded to the first filter cap ground point
Check that the bypass cap on the resistor is the right way around
check that you actually have the bias resistor connected to the right pin on the power valves
Check all the power valve connections are on the correct pins.
Check the 220K grid leak resistors are correct value and connected to the grid pins on one side an ground on the other
One you you have current flow your voltages will drop in the whole amp
The voltage in the amp will come down once you have this sorted.
Suspect this is something you are missing - don't worry it happens to us all !
Edit: my suspicion is a problem with the screen voltage, so check that area, around the 2nd stage filter cap and the 5K dropper resistor as well as the above.
Could you have connected the cathode resistor to pin 1 instead of pin 8? Or not connected the filaments up correctly? eg to pins 1 and 7 instead of 2 and 7. Just a thought…
I'd also check you have the correct voltage on the power valve screen grids.
No voltage here and the valves will be off.
I would first check the resistance from the valve cathodes to ground. If this is 250 ohm you need to look else where.
Aye, I also wondered if'bugger were lit!
Whenever you build anything electronic it is a good idea BEFORE you put power on the kit to clip a meter to 'chassis' and go round valve or IC pins and check resistances. Often you get a funny reading, especially with stripboard jobs where a track has not been cut or 'blobbed' or 'whiskered' across.
Please don't give up on DIY 'tronics! There are SO few people doing it these days. Many audio forums have a DIY section and most stay empty of new projects for weeks on end. If you want a bit of one-on-one I have the time unlike many of the chaps here perhaps. Just PM me.
Dave.
It sounds bloody lovely now I've added those two wires and cleaned it all up. I'll post a pic in a bit to celebrate. Thank you all of you, and sorry for being that tit again!
https://drive.google.com/file/d/1Ka8Hu6vbT0wnz19_9ED5B_-Yt5QssqDm/view?usp=sharing
Cool cab, well done
Oh! I am sure there are dedicated forums full of somewhat geeky electronics DIYers! I have no interest in those and they probably find all the help they need. No, I infest just AUDIO and recording forums where the posters are not interested in electronics of itself but as a means to an audio/guitar related aim.
SO many of these guys and gals have NO clue about even basic connectors or current flow, gain matching etc. Fork! Few even own a test meter.
HOW some of these people learned to read, drive a car, got a job and operate a computer (often WAY better than I!) but cannot follow Ohms Law I do not know!
Dave.
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
