Pretty reliable, although the preamp out/power amp in jacks are a weak point - because they never get used, so the contacts corrode.
£25 is a good price if it's all working OK. Ideal as a practice room amp, a backup or a rough gig amp you don't mind lending out to other bands - quite hard to kill and not worth stealing!
The issue with the jacks actually affects the straight-in sound, not using the loop - it's the switch contact that bypasses the loop which is the problem. Easy enough to fix anyway - cleaning the contacts almost always works first go, although sometimes it takes more than just squirting some cleaner in from the outside.
PRESENCE>VOLUME>BASS>MIDDLE SWEEP>MIDDLE GAIN>TREBLE>GAIN
Then there's three toggles underneath the knobs:
LIMITER>EQ>PRE-SHAPE
I'm guessing the LIMITER is some kind of compressor that squashes frequencies down? The EQ bypasses the EQ section (quite like this, a direct route to a nice basic tone, no messing)? And I have no idea what PRE-SHAPE does. Any ideas?
The real test will be in a band situation to see how it fares at volume and wether it can be heard against other loud instruments. Will hopefully get to find out on Tuesday night. Then gigging it Thursday night
Limiter is just a sort of compressor that only kicks in at high volumes to stop the power section overdriving (potentially not good for it, or the speaker). At lower volume it probably won't seem to do anything.
Pre-shape is a low-mid cut and possibly upper-mid boost, I can't remember - Trace Elliot popularised this with their early amps, and Laney copied it. Later Laney bass amps got even more Trace-like, with a graphic EQ as well.
