Big handle and head problems
JetfireJetfire Frets: 1696
On my lovely Bogner 1 x 12 cab, the handle is on the top and its a pretty bogo standard carry handle. The soft case I have that goes with it has a space for the handle to go through it so sadly removing the handle isnt an option.  My problem is that my little h and k head sits on this handle and is a little bit wobbly. My thoughts were to extend the amps feet  a little bit and it would solve the problem but if I did that, the snug amp head case would catch on it.
First world problems I know but can anyone think of a way round this? I'd buy and amp stand with a seperate head section but I ain't spending 70 quid on a quiklok one!
  • welshboyowelshboyo Frets: 1818
    edited November 2017
    what about those self adhesive felt pad things for the bottoms of chairs on the top of the cab?
    or, I know it will look pants but put the Bogner on its side??
    or sell it back to me
  • ICBMICBM Frets: 72600
    Carefully rout a recess into the bottom of the amp head so it will fit over the handle. This will also prevent the head from vibrating off the cab.
  • ecc83ecc83 Frets: 1639
    Make an 'Interface' plate out of ply or MDF of the required thickness.  Can be used as added speaker protection when kit is chucked into the Transit.
    if you 'have the technology' you could route depressions for the feet and get the stability ICBM mentions. If you DON'T have the tech, make the plate with laminations.
    Dave.
