The valves won't really make it quieter though, it's more that they will give it a bit less gain and open up the tone. A volume box in the loop is by far the more effective for low volume.
I don't think you'll acheive what you want to by changing the valves - the volume control in the s/r loop is the best way I've found for taming my HRD. And it sounds great now, even at home!
Its a bleeding loud amp for its size!
Less gain, clearer and with less midrange, and more punchy dynamics. You might get *slightly* more control with the volume knob, on the clean channel - but not that much. It won't make and difference on the drive channel, although it will reduce the effective amount of drive - which is a good thing in my opinion, I don't like it above halfway if you're going to use More Drive.
I do like them in some amps - they're great in V1 in a Peavey Classic 20 for example, where they reduce the gain to a sensible range instead of the Metal Zone emulation it normally does...
Also the cathode resistor is optimized for biasing a 12AX7, so a 12AU7 will not be biased correctly.
You could modify the amp to accept a 12AU7, but that would probably be more trouble than it is worth.
That said, a volume box does make it easier still and I think does improve the tone a bit, just because it lets you get the controls out of that 'only just on' zone.
The other day I was listening to an album by a local band which was recorded with a stock HRD and as far as I know from seeing them live, no pedals - and the guitar tones are fantastic, both clean and overdriven.
