This could be absolutely stupid sounding but here goes...
Help me understand things! Lol.
I’ve heard fuzz pedals don’t like buffers..
I’m currently using a Boss Tu-3, a Boss Oc-3 and an angel wing in my chain. I know the 2 Boss pedals have buffers, the third is true bypass.
However, I considered picking up a tone city fuxx fuzz as its cheap. But after reading up on fuzz disliking buffers, it could just be a waste of money if it doesnt work properly eh!
This led me to think about the Boss Fz-5 Fuzz pedal.. I understand its basically a modelling pedal, a digital replication of fuzz sounds rather than a typical fuzz box circuit? Either way, being Boss, it has a buffer..
So my ridiculous question is..
Does the Boss fz-5 play well with buffers or other Boss pedals containing buffers?
Also, as my Tu-3 is first in chain, from my understanding it acts as a buffer, because it contains a buffered bypass. Same as my Oc-3 which is second in chain I guess.
Now, my guitar cable is plugged into the input of the tu-3 obviously, and the patch cable from the tu-3 comes out of its ‘output’ jack, not its ‘bypass’ output jack.
This is so when I stomp on the tu-3, it mutes any guitar sound while tuning.
So my second question is, even if the tu-3 is off, like when I’m not stomping on it and tuning, is it still acting as a buffer?
If so, I presume Boss pedals always draw some power even when off to power the buffer? I guess this is why the input jack also acts as a power switch, so if you are running off of battery power, you’d want to disconnect any cables from the input jack after use.
Trying to learn about it all!
Thanks for any insight!
You could run Fuzz - OC3 - Angel Wing - TU3 - AMP
There is certainly no reason to miss out on all that fuzzy goodness because you are running a few boss pedals.
The boss fz-5 will be fine wherever you stick it but I wouldn't recommend as it sounds absolutely gash
There are a number of fuzz pedals that work fine with buffers also. All mine do.
Fuzz faces and their derivatives (but not all of them) need to be first in the chain because of the way they interact with your guitar's pickups, but Big Muffs don't.
You'll either hear a difference- like a night and day difference- with the fuzz after the buffer, or you won't. If your fuzz doesn't like being after a buffer, put it before- you'll want it early in the chain anyway. Job done.
With regards to Fuzz pedals and buffers, yes, some (not all!) fuzz pedals don't play well after buffers but they're all fine before buffers. If this is the case just put your fuzz first in the chain before the tuner.
The Fuxx Fuzz appears to be based on a vintage Foxx Tone Machine so I suspect that you'd want it up front before the TU-3. Have fun!
Right, so i’m looking at the Electro Harmonix Russian big muff. Mainly beause it looks freaking awesome, but also seems to get good reviews.
The standard bigg muff pi ones arent much different in price, so they are also an option.
Any thoughts?
I do play with emg actives a lot, and also its going to be through a clean channel on the katana 50, so solid state. I wonder if I’ll get useable fuzz out of it?
i presume these muff fuzzes are pretty high gain, being a fuzz type pedal. But any insight is always appreciated!
As already said the Big Muff is fairly immune to buffering issues.
But as also already said, the Boss FZ-2 is even better - the actual fuzz circuit is a copy of the Shin-Ei FY-6 (AKA Univox Superfuzz), plus it has active EQ as well as the two fuzz modes so you can get a huge variety of sounds - and it even has a clean boost mode (bypassing the fuzz, the EQ still works) if you get bored of fuzz. The bad news is that they're discontinued and not all that cheap nowadays. But they are my favourite fuzz ever - even more than the one I named myself after...
