Hi,
I have recently picked up a used 65 reissue Princeton reverb which sounds superb but is showing up a strange issue with the reverb.
Basically, upon firing up I’d say the reverb works from the off 2/3 of the time but on the other occasions there’s nothing. It always kicks in after 5 or so minutes of playing and once on, doesn’t falter again. The reverb sounds exactly as it should when working.
I’ve changed the v2 12at7 for a brand new groove tube but the issue still remains.
Any ideas what it could be? Could I be causing any damage using the amp?
Other than the reverb issue it sounds perfect and runs really quietly.
Any advice would be much appreciated,
Cheers,
Dan
It's unlikely you'll be doing any harm, unless it's a bad connection in the reverb tank send transducer or the cabling to it which would leave the drive transformer with no load - but from the description that doesn't sound the most likely.
Thanks for the feedback chaps, it’s not like I’m gigging or anything so as it sounds so good and is not causing any damage I’ll probably leave it as is.
I guess a service/repair should be factored in at some stage. Any idea where I could take it in the Herts area?
