Ok, I’ve been toying around with solutions for getting a decent sound to the PA at medium sized venues where the amp on it’s own isn’t enough. I want to keep using my valve amps on stage and get a consistent feed to the PA, reactive load boxes with decent outs cost loads so how about this... a Marshall voiced preamp pedal I can stick at the end of my pedal board with a 1/4 inch through jack to go to my lovely valve backline line and an xlr emulated speaker out to go to the PA? I’d like to keep things analog if possible, I’ve been gigging a line 6 rig for ages now and I’m sick of it. Any pointers or recommendations? Thanks.
just found the Radial direct drive which looks cool...
http://frogpedals.com/index.php/product/frog-tube-preamp-fx1/
The Blackbird is equally as good too. I have one and it's bloody stunning. Bit cheaper too.
Have a look at the Radial Rack units on their site - in my mind I'm 99% sure they've got one that does this. Also check Palmer's site.
A bit different to what you're envisioning at the moment but how about the CabZeus cab emulator? Digital, admittedly, but will go between your amp and cab and give you a speaker emulated out to the PA while allowing the signal through to your speaker for on stage. And not too pricey.
I had a Kingsley Squire which was OK ish but wouldn't be a good fit as it's the wrong voice and is not emulated out, but their stuff is generally well thought of so maybe one of their other efforts would work too
soundcloud.com/thecolourbox-1
http://www.koch-amps.com/product-guitar-pedal-preamps-superlead.html
Ignore the name, it's much more 'Marshall' sounding than you would expect. There is a reason for this... the circuit is nicked from the JMP-1 rack preamp, without the MIDI and digital control .
Have you seen the ShiftLine pedals?
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
Bandcamp
I've got the F-! and it replaced my Sansamp GT-2.
