Right, I know what you're all thinking, why are you listening to some ginger twat with over saturated marketing and PR, but aside from this, I do like the sound he's getting from the guitar for "Thinking Out Loud". I've been trying to figure out if he's driving the amp with a distortion turned down or is a sparkly clean sound with some form of effect on there.
https://www.youtube.com/watch?v=uW8Hci4YSG4 At first it sounds like a clean sound but when he does that hammer on it sounds like its got some overdrive on there.
Anyone know how I would set the amp up to play with a strat, might need to do this in a covers band one day!
The slightly overdriven sound is the other guitarist in both clips.
By reducing the low mids the guitar signal will be clearer and you will hopefully start to get the "spack" you are after.
You don't need more pedals. And at the end of the day just get as close as you can, absolutely no one else will notice or care about the sound!
Edit: Here’s the boss pedal. Looks cool to me, has the Blackface EQ to it and reverb built in. https://www.boss.info/us/products/fdr-1/
Seen a few cheap reverb/compressor pedals around on Gear4music for about £25, not sure if they're good though.
No tremolo footswitching - you can only turn the whole 'amp' on and off. (Or reverb, although that's probably not so much an issue.)
No speaker-emulated output so you can't use it (or not without something like a Red Box) as a direct-to-PA solution.
Knobs are in the wrong positions/order to adjust the ones you're most likely to want in a hurry - gain and volume... they should be the big knobs, at the ends.
I do like them though, and I'm about to get another one.
