Last year I took a bit of sandpaper and wire wool to the neck of my cheap Aria hollowbody to get rid of that sticky feeling. This not only improved the playing feel but I also rather liked the satin look that resulted, and began to wonder whether the whole guitar wouldn't look much better like that.
Last night I attempted it but it didn't quite go to plan. The guitar is a kind of tobacco sunburst and it turned out well on the translucent bits, but the black parts have turned very dull with a sort of milky white on top (no pics I'm afraid).
What have I done wrong, and how can I get it right again? Have I sanded off too much, or too little? Do I take some polish to it, or sand off a little more? Or just try and buff it vigorously? I think one of the reasons the neck came out well is that it got smoother with use.
Oh, and while I'm at it: who does the cheapest good quality wiring harness? I'd like to replace the pots and switch which are all sub-standard; pickups were upgraded to Oil City Mighty 90s as soon as I got the guitar a few years back.
This is quite an amateurish attempt, I followed a guide on I think the Seymour Duncan forum. To do it property you need to take everything off the guitar. I did it with a cherry gibson es335 copy, if you look closely there are little scratches in the finish but I was pretty pleased.
I would only do it to a cheap guitar though,
By the next string change, I'll hopefully have purchased a wiring harness and 2000 sandpaper to finish the job.
Any tips on wiring harnesses? Or on where to buy quality components? I should be able to build my own.
