https://shop.pedalparts.co.uk/Simple_Circuit_Tester/p847124_15641222.aspx
Thank me later
So I just wire that doodad up to the BB and I'm good to go?
its basically the switchy/input parts of an effect pedal...
he also does this: https://shop.pedalparts.co.uk/Ultra_Tester/p847124_15700704.aspx which has a few more testing features...
Now to solve the pots problem.
the six way in the middle is for use with his own six way ribbon he uses on his kits - direct connect he calls it.
Unless you build one of his pcbs just use the two blocks.
jack in - circuit in - v+ - gnd - circuit out - jack out
left to right as you look at it...
His direct conect stuff is useful for really neat builds tho’
http://a66.tinypic.com/2uz43ti.jpg
