Morning Chalky and a HNY! I know gitamp makers often run the A off valves but the limiting values given for the 6V6 G are Va 315, Ia 35mA and Pa 12W although there are many variations of the V6 and lots of different specs.
I found a (French) data sheet for 2 valves in p-p. Va =285, Ia (no sig) = 70mA total which gives an Rk of 256 Ohms. The power for 3.5%thd is given as 14W. Anode dissp' is a sensible 10W.
Generally if you want early breakup, go for lower HT voltages. Raw power, 300V + but do remember that I suspect 6V6s are now NOT the valves I found to be virtually indestructible in old radios!
Dave.
Ah right, so as a home player it sounds like the 250v plate voltage is preferable, as early breakup is nice and I don't need maximum volume. The 6V6 i have is marked 6V6GTA which suggests its a more modern variant than the oldies but goldies you're talking about Thanks!
No worries C! I recall now that I fixed a couple of amps in Bell&Howell projectors. They used the very compact 6V6, 2 in ppull. Cine projjies got hot and the valves were subject to a lot of motor vibration but they rarely failed, usually it was caps wot went both eletros and foil.
BTW if you want an even quieter amp, fit a triode operation switch.
Dave.
250V is too low really, that will give quite a middy, mushy sound with very early breakup and not enough clean headroom in my opinion. (Although you may want that.)
If you have a scope it’s probably worth experimenting with cathode resistor values to see if you can centre the waveform between forward and cutoff clipping better than just going with 470 ohms, if the breakup is too early.
Not sure if Chalky has a scope but he IS an IT man so a PC scope progg' should be easy for him to sort!
You could use a 500 Ohm 2W pot to tweak the bias and then measure it and make it up from fixed Rs.
(that French spec I found (385V) seems about on the money IC. I have the .pdf)
Dave.
Va-k - 300v
Vg2-k - 290v
Vk - 20v
Rk - 470r 5w
PT is 275-0-275 @ 90mA
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Rift Amplification
www.riftamps.co.uk
Rift Amplification
www.riftamps.co.uk
