http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
The trem was really responsive, tool.
Overall, it was a vast improvement over the Fender hardware
Edit: mine was a rosewood board, alder body
Removed it and put the fender trem back in and the low end was restored.
Also just tried callaham saddles with the fender unit on my CS rosewood veneer neck and alder body with similar results. Bright and plinky. But better sustain. Bit of low end loss. Same strings, setup and action.
On both of these strats im gone for CS block and plate, callaham six steel screws and raw vintage saddles. Not sure if the callaham screws make a difference but I liked the sound of the one so replicated it across to the other strat. Raw vintage saddles are superb.Bit softer sounding.
If you have a fender trem unit (with steel block) im not sure its worth the upgrade. I would probably upgrade the saddles depending on taste if you do.
Callaham stuff is excellently made but I think its made too well if that make sense? Very good if you want a ballsy strat or your strat is a bit lifeless.
It's never even crossed my mind to try any other trem in there so I guess that says it all.
Suhr offer the Fender assembly (or certainly used to - I haven’t visited their site for a while) for those who wanted a vintage-style trem on their custom-built guitars. JS seemed to suggest this was based on tone - given he is an ex-Fender employee - I’d imagine his instinct would be to use a small supplier in preference.
It sounds to me like the Callaham assembly - or Raw Vintage saddles offer a way to tweaking the tone in much the same way as swapping pick-ups does. So whether it would be a good idea really depends on how happy you are with the guitar ‘as is’.
The slop mentioned isn't as bad (by a long way) as the Fender unit (even with the easily lost spring) and can be adjusted with an allen key.
My issue with it was that the bar used to pull out in use - or at least pull up. I only use my trems for gentle hand vibrato - think Gilmour/Marvin - and I found that the bar would pull out over time and would need pushing down, sometimes mid gig.
However, it sounded magnificent (big block version) and was really responsive.
