Fretboard radius
As far as getting a nice low action is concerned is there that much of a difference between 12" and something like 17"+?
I was just looking at some vigier guitars which are famed for their action and they all seem to have a 11.8" radius.
  • ElwoodElwood Frets: 455
    No, I think it's in the feel rather than the action. On a really flat fretboard there is very little relative height change between strings. You could have the same action setup on a 7.25" as a 17" but the smaller radius would make a noticeable difference in height if you moved from the Low E to D, for example.
  • Not sure about that, you can't set the action too low on the old low radius strat necks since the notes will choke out when you bend. I'm just wondering if diminishing returns kick in at some point.
  • SunDevilSunDevil Frets: 511
    edited January 2018
    You can definitely go lower with a longer radius - for example Fender stock relief and action heights drop as their fretboard radii increase
    I believe this is as a flatter board is less prone to choking bends.
  • Winny_PoohWinny_Pooh Frets: 7788
    12 & 17 will be less of a difference in action between 7.5 & 12.
  • TheMarlinTheMarlin Frets: 7914
    I prefer 12”’ radius.  I recently acquired a Hagstrom Super Suede 3xP90 with a 15” radius neck.  I can feel the difference.  its taking a while to acclimatise. But, that could be due to its fuller Gibson style neck but with a Fender scale. It’s heavy too (mahogany with carved maple cap and Tremar/Bigsby.  I find heavier guitars are more difficult to play seated.   Lots of things influencing my perception of how it plays.
    Can see what you're asking; I can't think of any reason a flat fretboard would require a higher action than, say, a 16 inch but I don't know the answer.
  • In feel between 12" and 17" ? Not as much as you'd think, but it depends on how you play, and who makes the guitar.
    Some makers add fall away into the fingerboard ( you can get a PRS to have super low action without it choking in bends and they have 10" radius, but try that with a Fender) so you can't always compare specs like for like.
    I have a few guitars with a 20" radius, and when jumping from the A string to the B string it's nice to not have go over a hill, but my ce24 with the 10" plays just as well.
    I would like to try the Shawn Lane Viger without a radius , tho.
  • CollingsCollings Frets: 411
    Yes in theory I think there is a link between fretboard radius and action. Guitars with a smaller fretboard radius tend to fret out on big strings bends easier.
  • WezVWezV Frets: 16746
    edited January 2018
    Slightly flatter than fretboard radius is optimal, with it skewed slightly higher on the bass side.  This is due to string thickness and action height
    the overal action needs to be higher on a tighter radius for bends, but this is seperate to the point in the first paragraph
    I've read posts by people with prs guitars saying how low the action is with 10" necks compared to other guitars, this just confused me more.
  • RolandRoland Frets: 8743
    There’s a lot of rubbish posted on the internet. PRS’ tend to have low actions because they are well designed and built.
    The key point here is @Collings’. If the radius is too small then bends on the higher frets will choke. The exact numbers depend on geometry: the radius, how high on the string you’re bending, how far you’re bending, and how high the action is.
    On the other hand some people find it harder to hold down chords on flatter fret boards. There are guitars which use compound radius, eg 9.5” at the nut and 12” at the 12th fret, to get the best of both worlds.
    Thanks for the info.
    I've read that you can get a 1.5mm action on the high e at the 12th fret on a vintage 7.25" radius neck so i presume on a 12" radius vigier you could get it lower.
    It's a bit of a pain trying to find a high radius neck guitar with stainless steel frets and a 2 post non locking trem. Seems to be either expensive boutique guitars or kiesel/warmouth customs. None of them cheap!
    @2003amxl Some of the new 2018 Ibanez models, AX, have exactly that spec. Not sure on price, unlikely to be cheap but should not be Suhr pricing levels.
    Is there a reason why bass strings being thicker don't seem to make a difference?
    I can get 1.5mm at the 17th on my P bass - it has a vintage 7.5mm radius board..
  • flying_pieflying_pie Frets: 1817
    I'm guessing you won't do lots of bends with your bass. That would be the factor making the biggest difference
  • richardhomerrichardhomer Frets: 24843
    How far do you bend them?
    Funnily enough, though not bends as such, I do use quite a bit of vibrato further up the neck - and I'd say it's a fair distance either way to get a noticeable effect
  • WolfetoneWolfetone Frets: 1479
    You can go as low as you like with any radius but don't expect to do any serious bending with a small radius. That's why compounds are awesome.
    Perhaps. But that's not quite the same as playing the bends in the solo to Another Brick In The Wall Pt 2
    Indeed. But my original comment was more the reference to 1.5mm at the high E, and a bit higher at the other end.
    I doubt many bend their low Es that regularly, so the action height is about fret rattle. With a low E around .46, it's the same as the high G on a bass (.45 typically)
    I can happily have a 105 E on most of my basses sitting at 1.5mm action and have practically no buzz.
    Bending aside, the lower strings often have a slightly higher action to cope with buzz. I'm thinking it's more to do with the right hand technique and how much a string vibrates on guitar compared to bass.
