I've rewired a Thinline with two single coils - I 'think' it's noisier than it was before
I've only changed the switch, pots, cap and associated wiring - pups and bridge are untouched
There's nothing that suggests it's a grounding issue (to my an my idiot-level knowledge of these things) - there's nothing metal I can touch that reduces / increases the hiss and there's nothing suggesting a dodgy contact in terms of noisy or farting out of the controls
The middle position is no quieter than positions 1 & 3 - pickups are wired as before on the new pots and the neck pup has 3 wires
Hiss increases with the tone pot and drops when the signal drops with the volume down
The tone cap is resting on back of the tone pot with it's legs insulated to avoid a short - left one of those legs long to ground out the cap to the back of the volume pot via the 3rd lug of that pot
It wasn't a quiet guitar before and I may be imagining this (such is my level of confidence in my soldering!) but any suggestions that I could look at?
I'm going to swap to modern wiring an a treble bypass and a 0.1 tone cap in the next few days, so it would be a good time to try and address the background noise, even if it's no worse than before
Being a Thinline, there's no metal plate to attach the controls to, only a thin piece of stick on shielding on the back of the pickguard - tempted to go with a metal guard!
Baz
The version 1 Tele Thinline uses the same circuit as the solid body, the one difference being the metal control plate that forms part of the grounding path. On the Thinline, it might be worth running an insulated wire between the chassises of the two pots.
Remotely diagnosing much else will be impossible without photographs of your wiring.
Following my first post, I matched the Thinline up with a regular Suhr Classic T with original wiring and the background noise is near enough identical.
I've had the Suhr for 3 years and never considered it an issue, so I think it's a storm in a teacup in this instance, but appreciate the reply none the less
Cheers
Baz
