Hi all,
Any help or advice would be much appreciated.
Anyone had any experience shipping amps over-seas?
I've been contacted by a very nice chap, on this forum, re my Dr Z Carmen Ghia. He's based in Sweden.
I've never shipped anything oversea's, not so much as a pedal.. or a CD.
Anyone do this regularly.. or any experience at all in doing this?
If so, any advice on methods.. hints and tips. things to be wary of / precautions to take.. etc.
Thanks in advance.
Jack.
''i've not seen a reaction like that in here since George Best got kicked out for glassing a bouncer''
Pack it to withstand a drop onto concrete from a height of several feet. This can be difficult with heavy amps with large transformers and speakers - the internal inertia can do damage even if the box protects the outside of the amp. To do this you will need to either double-box it with soft material between the two, or use a thick layer of polystyrene sheeting round the amp inside a strong outer box. Proper high-density foam 'shipping corners' will help. You need to keep the amp at least an inch away from the outside, preferably more.
I would remove any octal valves (large-base power valves, and rectifiers) and wrap them separately in a jiffy bag inside the amp - they're prone to damage from shock. Preamp valves and EL84s are usually OK left in the sockets, although if you're worried you can take them out too. Label the valves and which sockets they came out of with masking tape and numbers so the buyer doesn't put them back wrongly.
If it has an attached power cable, make sure it's well secured or also wrapped in a jiffy bag - the plug can cause damage if it flaps around. If it's a kettle lead, don't bother including it - the plugs are different in Sweden anyway and he will need his own.
Pray .
Does that help?
Thanks a million for your help.
Best,
Jack.
Good luck either way!
I have and do ship amps abroad without issues. Insure them in case they go missing, and pack them so it's impossible to damage them; Yes, it can be done.
I don't agree that insurance is a waste, but only in case the amp goes completely missing. Which is highly unlikely with a tracked shipment with a reputable carrier, but even so....
Get a double wall carton a good bit bigger than the amp, and a roll of 'large' bubble wrap. Don't use the normal 'small' bubble or anything with less bounce. I wouldn't use high density materials myself.
Use a minimum of 8-10" of that all around the amp (on top too, don't forget it might get inverted), and some extra card on each face of the carton to prevent punctures and to add strength. There shouldn't be any space in the carton, the amp should be snug, but not too tight.
Tape it well with heavy duty tape.
It's expensive in terms of packing materials and the extra size will add to the price, and it takes ages to do it right, but this will absorb the impact of drops from a few metres. Leave the valves in and protect the entire amp from shocks.
I've been doing it that way for a few years now with no problems at all, so it works for me. However, doing it right is expensive and time-consuming.
EDIT: I forgot: take pictures of the package and during the packing process, for evidence in the event of an insurance claim.
I'm still currently in the camp of hanging on for a UK buyer to be honest, and placing the blame on January finances for the lack of interest.. ha!
Mainly just due to the extra work (kindly laid out in detail by Martin), and added risk. I love this amp, and hate the thought of anything happening to it. Almost makes me want to keep it.. ha! But seeing it go to a loving home will be enough i think.
I will however bear all of the above in mind, should this opportunity present itself to me again in future. And thanks for taking the time to tell me about your experiences.
Jack.
I'm not a fan of bubblewrap alone for heavy items, because it usually pops at the main impact points, the edges and corners, and it becomes basically clingfilm and useless. Use polystyrene.
Do not go with the cheapest courier (Hermes etc). Pay a bit extra and go with one of the better ones, UPS have always been great for me.
btw mods, is it time for a sticky about couriering amps?
