So I was going to buy something new but then thought it must be possible to mod my existing pedal. I have a BYOC tubescreamer (either 808 or TS9, not sure which, how do I find out?) which I generally like for boosting apart from the bass rolloff sometimes. I want to add a control to adjust the rolloff frequency from stock to a fair bit beefier so I can dial in the right amount - ideally a pot but could do it on a switch if thats easier.
Seems like this is a common mod (change C3 to alter the rolloff frequency) but I can't seem to find a straightforward DIY guide for doing it on a pot or switch. Any tips?
I must say that I prefer it with the mod enabled, it's very thin without it.
I haven't tried it but going by the website I linked to, an 0.1uf capacitor should be a good value to try.
If you have a SPDT switch (one with three terminals) and with a centre off position, you can have three settings.
Connect the centre terminal to one end of the original capacitor. Connect one of the other terminals to the other end of the capacitor. Connect the new capacitor between the two outside terminals.
Hopefully someone can correct me if I am wrong but that should give you three options.
1. Completely bipassed - full bass response
2.(centre off) original behaviour
3. New capacitor in parallel with the original, increased the value therefore extended bass response.
You might also want to try an 0.047uf new capacitor instead of 0.1uf. As I said, I haven't tried it and I am just going by the suggestions on the Web page I linked to.
https://i.pinimg.com/originals/63/e1/f0/63e1f023e299fa9d3f709dc98934bb27.gif
Edit: Just realised you said "a cap across the PCB pads as well" in which case yes, you would be adding the new ones in parallel, and centre-off would leave just the original in the circuit.
