It should look like this -
https://www.premierguitar.com/ext/resources/images/content/2103_08/Blogs/Sep13_PG_CLM_ModGarage_image_WEB.jpg
Is this the one with the routed-out control cavity? The wiring has definitely been buggered around with, anyway - the tone pot also appears to be wired very strangely, the right-hand terminal seems to be grounded which is wrong. The volume pot has been replaced as well but I assume you knew that...
