None of that info is applicable to the modcat code - do you have the swing tag or indeed is the bar code label still on the case - both will have the modcat code letters if you have them - Should start with an H for Hollowbody
My band, Red For Dissent
Here it is:
https://imgur.com/a/1Ufiz
so a) what do you need to know and b) send the serial number to PRS USA Customer service and see what they have to say about it - they are normally quick on replies custserv@prsguitars.com make sure you include the serial number
