As things stand, I see two black insulated conductors soldered to the chassis of the volume pot where I would expect to see three. One ground per pickup plus a third one to the output jack socket.
In my opinion, the existing solder on the two black conductors does not look especially convincing. It might be worth doing the four joints for the pickup conductors again using fresh solder to ensure good contact.
If the guitar were my own, I would examine the undersides of both pickups to check the condition of the connections on their fibreboard bobbins. NEVER assume that brand new stuff will work straight out of the box.
I accidentally broke the thin copper wire from the coil to the hot lead of the pickup. I've redone the solder joints though, so when I get a new one (again!) all should be good.
If the break is between the coil and the soldering eyelet for the white ("hot") output conductor, a skilled hand can unwind one turn of the copper wire then, tie and reconnect the working end.
That skilled hand is Ash at Oil City Pickups. You need to contact @TheGuitarWeasel directly. I can not speak for the likely charge for the repair work plus two-way shipping. It should still be less than the price of another pickup.
(A soldering iron with a fine pointed tip helps.)
