Hi,
I've just bought a new swamp ash body for my Squier E series strat .Love the neck but wanted to convert the guitar to a hardtail. So I got the swamp ash body from GuitarBuild and the Gotoh hardtail bridge
https://www.axesrus.co.uk/Hipshot-Stainless-Steel-Hardtail-Bridge-56-4mm-S-p/41300.htm). Neck and bridge fit perfectly but once strung the strings lie muted flat across the neck. I have raised the saddles pretty much to their full height but theres not enough height to clear the neck. I don't want to shave the rear of neck in the pocket to reduce the height as if I'm not happy with the build i want the option to simply put the neck back in its original body.
Any suggestions? I guess a shim on the hardtail would work? Is this the best approach? If so what should I use for the shim?
Cheers all
Ideally you need to rout the neck pocket in the body deeper, but that's quite a difficult job if you don't have the right tools. I would either put a riser under the bridge, or try to find some extra-tall saddle height screws - although I don't know if that would make enough difference.
If you want to make a riser, something like a piece of plastic pickguard material will work very well - it's easy to cut and drill. If the body is a string-through then it won't matter that the bridge screws are going less far into the body, there won't be a lot of force on them.
the chart should give you some idea as to where to aim (1962) to get the geometry correct.
http://a63.tinypic.com/21cy2rm.jpg
You have two choices, deepen the pocket or shave the neck...
what i did was mill .040” of off the neck heel
http://a67.tinypic.com/w47sj.jpg
geomety now bang on ‘62 specs.
Really appreciated. I don't have the tools or the inclination to shave the neck purely because I want to retain the option to put it back into the old body if I'm not happy with the results. So I'll try raising the bridge and see how that goes but most likely try to find a guitar tech that can deepen the pocket.
Thanks for the measurements poopot I suspect it will save a lot of pain
Cheers
Pete
milling that neck cost me a whole five pounds!!!!
