The bass Fender should have made (IMHO)
I’m back to a sensible project ;)
I have always thought Fender should have made a mainstream thin line telecaster bass.
So I got Graham to do one for me. Should be a fun build. It’ll be a stain finish, but haven’t chosen the colour yet.. hmmm
  • Is there a risk of it being annoyingly neck heavy?
  • Winny_PoohWinny_Pooh Frets: 7788
    edited February 2018
    Wrong pickup
    Defo investigate ultralight tuners for this one (Gotoh GB640 IIRC)
    Wrong pickup
    Nope. Ultralight tuners already planned. It’s not an overly light body, and there’s enough space in the rear cavity to weight it if necessary.
    And if it’s a Lindy Fralin split coil 51P then it’s absolutely the right pickup.
    Wrong pickup
    Good call
    Tele style headstock and 1.75” nut. Mmmmmm.
    Wrong pickup
    Good call
    Planned as part of the build
  • FunkfingersFunkfingers Frets: 14541
    Nice grain. Worth leaving it visible.
    Winny_Pooh said:
    Wrong pickup
    Lindy Fralin split coil 51P  ... absolutely the right pickup.
    In the interests of sonic variety, a second pickup would be desirable. I'd want an EB-style mudbucker but I can imagine the OP opting for a piezo-loaded bridge and buffered pre-amp.
    Winny_Pooh said:
    Wrong pickup
    Funnily enough, the bass I use most live is my (also Graham) home build 51P with a billy basic SD quarterpounder in it.
    It’s all thump and not much else but fits in really well with our sound.
    Piezo bridge is slightly tempting, but I feel the draw to making it a good old trad 51 thumper. After all, I’ve got a “posh” 64 thumper and it’s the tone I keep going back to.
  • ICBMICBM Frets: 72520
    Wrong pickup
    +1
    A WRHB is the right one for these. If you get a modern one with 4-conductor cable you can wire them in parallel, which makes them less overpowering - I did that on my recent Pawnshop Mustang Bass.
    I've played in a couple of places where a non-humbucking single pickup would make the bass almost unusable, so I would automatically avoid that now.
    ICBM said:
    Wrong pickup
    +1
    Yes, but my experience disagrees.
    I gig with a SC pickup and it's fine.
    I don't want a mud bucker - don't like the sound.. ;)
    You just haven't come across the wrong venue yet. I thought the same as you about my Rick until I did...
    That's why I rewired it in parallel. Slightly less output - although not as much difference as I expected - and a much brighter,  clearer tone.
    Anyway, the WRHB just looks much better in a Tele Bass, and that's the most important thing .
    Is the Lindy Fralin a humbucker anyway though? I missed that bit earlier...
    Don’t forget - I use a Preamp live to dial sounds in for different venues, and yes the LF is a split humbucker so basically a normal P bass pickup but not offset
    BTW @ICBM - the late 60s Tele basses were SC like the original Precisions until the 70s abominations ;)
    I am staying firmly in the early 50s camp, with a humbucking cheat
    I prefer the abominations :). They just look much nicer - I've never liked the look of the original P-Bass (sorry Leo!), it has none of the style of the '57 revision or of the humbucker Tele Bass. I agree that the neck mudbucker is too much though, at least wired in series.
    But Suzi Quatro played one, so there! [/10-year-old self with poster on wall]
    Nerrrr!!
    https://media.gettyimages.com/photos/american-rock-musician-and-actress-suzi-quatro-performs-onstage-picture-id481030011?k=6&m=481030011&s=612x612&w=0&h=BZNG8PZBgm1ok3KuNcShVXhrluJE146Kk7vAqtWmTJ4=
    Nerrrr!!
    I'm saying nothing.....
  • paulnb57paulnb57 Frets: 3057
    Jess Loueiro makes a decent split coil pick up too.........I have one in my 51 Franken thing (currently in bits for a rebuild)
    http://i.imgur.com/M2NFnt0.jpg
    http://jlguitars.eu/shop/index.php?id_product=68&controller=product&id_lang=4
    paulnb57 said:
    Jess Loueiro makes a decent split coil pick up too.........I have one in my 51 Franken thing (currently in bits for a rebuild....
    Nice - very similar to the LF - worth a look at I think.
    That is the classic 4 string Stingray formula. Humbucker in Parallel for clarity and EQ to boost. That's why they have so much attack even on the low E. The 5's give you the option of Series/parallel/neck single on a switch which is nice when you want something smoother.
    Try piling on enough distortion. (Jump to 3:05.)
    This is what I do with the DiMarzio DP145 Will Power neck position pickup.
  • TTonyTTony Frets: 27650
    I like the semi concept, but - to my eyes - the ornate F hole always looks out of place on a modern instrument.
    Fine if you've got a c17th violin, but on a c20th instrument design, surely there's a better design?
    That said, I've still bought them!
