On the Telecaster circuit, it is conventional to connect to lug #1.
On a Stratocaster-derived circuit, there is an argument for connecting to the same "common/wiper" terminal on the selector switch as you use to send the pickup signals to the volume pot. This is my recommendation if your circuit includes a Treble bypass network across lugs 1 and 2 of the volume pot.
For what it's worth, if you have just a master tone control, connect the two sides of the switch in parallel (4 wires connecting the matching contacts on each side - remembering that the rotor is at the opposite end on the two sides of a standard CRL-type switch) so they're both doing exactly the same thing - this will increase reliability and reduce switching noise.
Ideally, you should always connect spare switch poles like this because it increases reliability for no penalty (other than labour).
Treble *pass* . Treble bleed is what the tone control does. (Yes, I know it's the internet term... )
Removing it and connecting the tone control to the middle will also slightly increase treble as you turn the volume control down, but not as much. But it also makes the controls more interactive, so if the tone control is set lower than the volume it will *reduce* treble faster.
You don't need to change the tone control, the only thing that matters is where it's connected on the volume control. Some 50s wiring schemes do use a different tone pot connection but it doesn't make any difference.
Although personally I’m not a huge fan of it on Gibsons either...
