  • sweepysweepy Frets: 4209
    That is very neat indeed
  • paulnb57paulnb57 Frets: 3090
    Interesting idea but it is restricted to guitars with separate top?
  • ICBMICBM Frets: 72846
    That’s neat - but not that new, it’s essentially how Rickenbacker fit their necks, except that they glue them in and don’t use the wedge idea (which is very clever, I will admit). It will definitely need a separate top, I don’t think there’s any practical way of machining the slot in a single-piece body.
    Comments on the headstock shape? Probably the worst ever put on a guitar, it’s the ultimate combination of bland and ugly. And EBMM will sue over it anyway.
  • DanielsguitarsDanielsguitars Frets: 3302
    I like the wedge idea, I've thought about putting the tenon under the cap before, it would look good with just a bridge pickup when you want a long tenon
    www.danielsguitars.co.uk
    (formerly customkits)
  • SporkySporky Frets: 28939
    It's crap, but it's not even bottom 10%.
    After all, it's got straight string pull and enough space between the tuners to use them. That's a good start.
    But how do you actually turn the B string key? Which I've just noticed... :)
    And it is truly horrible - it's not even hideous enough to be interesting.
  • WezVWezV Frets: 16843
    edited February 2018
    i did a few of super long tenon's about 8-10 years ago, glued in of course although i like the idea for the wedge
    I still have one in the pile i keep thinking about doing something with.
    the body has already been reshaped twice since then
    today it looks like this.  you can just about make out the end of the neck in the badly cut pickup cavity
    I think its ugly as sin, but i shouldreally just cut a headstock and get some bloody parts on it
  • ChalkyChalky Frets: 6811
    If you are going to use a wedge method, why not use one of the Japanese locking type?
    I quite like the look of that! Kind of like a cross between a double-cut Gretsch Jet and a PRS, which is a very unlikely combination but seems to work.
    No I don't want it :). (Would need a trem, for me.)
    It needs a Gretsch-style narrow 'snake' head, I think.
    I think I remember seeing an example of that on a guitar somewhere
    here you go.  Scott Walker
    http://scottwalkerguitars.com/
    It's the upper horn that doesn't work for me, I'd look at cutting it off and reshape for some kind of single cut or reshape the horns, you'll have to get it done now
    It’s certainly not getting a 3rd reshape.... but I do think I can do enough with the carve to make it look a bit more intentional.
    Its on the list now, but may end up put away again for another 4 years.
    I've got a few to revisit so know how you feel, making from scratch is easier
  • RabsRabs Frets: 2620
    Ive done a few long full neck tenons before too..  Take it right back to the bridge pickup hole
    https://i.imgur.com/J8Y5Y4p.jpg
