FS - Nux Cerberus - Perfect condition - Analog driven multi fx unit - £190 Posted.
I've had this about a month but as usual GAS has set in...
Before describing this... Immaculate condition, boxed, with manual and power supply.
It's a brilliantly built (seriously!) and well thought out multi fx unit. The drive (based on a Blues Breaker pedal) and distortion (based on an Angry Charlie) sections are both analog and the modulation, reverb and delays are digital. The joy is you can use it like a stompbox and turn on what you fancy, and also use the CTRL switch as an added boost (with it's own dial), or to switch the reverb on separately from the delay, or switch the chorus on independently from the modulation. Very versatile feature, or you can save your effects into patches and change through sections in songs etc. IR loader, computer software downloadable to edit everything, 4 cable method or 2, MIDI, loads of stuff to play with and tweak...
Overdrive
Distortion
Modulation - Phaser, Tremolo, Univibe!
Chorus - CE, SC, ST Types
Reverb - Spring, Plate, Hall
Delay - 60's, 70's, 80's e.g Tape, Analog & Digital.
I've been massively impressed and would definitely keep it if funds would allow.
PICS :
https://imgur.com/a/hjmOpThe following videos are very helpful.
