Concrete lintel will look awful so you need a Catnic lintel and then you can replace a soldier course in the web of the lintel
I suspect the joists run parallel to the window as I can see a window opposite in the room and unlikely that joists run over both perpendicular in which case you do not need joist support during the operation just 3 strongboys (2 outside and 1 inside in the middle).......make sure you give the lintel min120mm bearing on each side
Maybe see if you can get a closer look at what is happening above the window frame? Is that something steel or just a thin membrane?
If that soldier course was sitting only on the window frame (!) you'd almost certainly see some fine cracking in or above the soldiers. None shows in the photos.
Maybe do a bit of exploring to see if it is covering the toe of a lintel?
You'll notice that the top of the soldiers does align with the brickwork coursing so, as the wall mortar joints aren't unusually thick, the soldiers seem to be less than a normal brick length - so maybe 7.5 - 8 inches long instead of 9" (230mm).
http://www.less2build.com/lintels/catnic-lintels-all-types/catnic-solid-wall-200mm/catnic-lintel-cn71a-1200mm-standard-duty
A couple of acros and a piece of 2x2 on the outer edge will keep the soldier course in place. (remember to leave enough room for the lip of the lintel. Then on the inside you're going to have to knock some plaster off to find out whats there, likely a timber lintel, which will need to come out. WHen I've done this I use t section steel inserted into the mortar joints above the top of the old lintel like in the photo. You'll need to be high enough to allow for the new lintel, I was putting a concrete one in.
Yet again I cannot get Dropbox links to work. Try copying and pasting
https://www.dropbox.com/s/0trz5zdazi9gv7d/DSC_0131.JPG?dl=0
If built in the 1930s it will not be a Catnic type lintel. Probably a concrete lintel but possibly even timber. A little bit of exploration is required, inside and outside, to try to establish what the construction is above the window.
The wall in the top photo looks sound with no obvious signs of settlement so I'll be surprised if you don't find adequate structure over the window but proceed with caution and be prepared to prop before anything is removed as advised by @Budgie.
Removing the wall below the window should not be a problem. You'll need to close the cavity each side of the opening.
With vertical soldiers rather than an arch the probable current configuration is a concrete lintel with a shelf angle.
It's unusual to find a loadbearing window frame except for some bay type windows.
You need to do a little more investigation to determine what's there but my best guess is that it'll be already suitable.
The windows have been out at least once before without, it appears, any undue problems.
If I had to bet I'd say there isn't a lintel as it would normally run with the brick coursing and the soldiers have been cut between courses.
I'm guessing some sort of plate over the frame..
