The only problem we found with it is that it's very bad for leaking noise into other pedals (especially fuzz) on the same power supply - even with an isolated output it wasn't silent. The only way to cure it completely was to use its own mains power supply separate from the rest of the board.
And the 'momentary' setting is a pain in the arse if you accidentally set it like that...
________________________________________________
Telecaster American Deluxe, Cornell Romany amp, without the talent to use them properly
