50 memory locations for the storage of user-created patches
30 preset patches
100 guitar effects and amp models, including modulation, equalization, delay, and reverb (plus 72 additional effects from MS-50G Effect Manager)
Up to 6 effects can be used simultaneously, in any order
Imagine that each preset on the Zoom is a pedalboard made up of 6 spaces for 6 effects. you can add just one effect or fill up all 6 spaces with 6 effects - it's up to you.
So, as an exercise, try this:
Turn it on, and hit the middle rotary button. Turn the middle rotary button and select preset 2 which, I think, is 'ClearCho' (if its got the factory presets on). Press the middle rotary button again.
So, you should now have a chorus sound, and on the display will be a graphic that looks like a stomp box. You hit the footswitch to turn the sound on and off.
Moving any of the 3 rotary knobs will alter parameters such as volume, depth, etc.
Now, to get into adding more effects to that chain, when you have the stompbox graphic up, hit the button to the left of the footswitch. What this does is display the next effect in the chain to the left. Signal flows right to left (like on a pedalboard) so once you navigate to slot 2 or 3 you can press the right button to go back up the chain.
Now, I don't have the box in front of me, so I don't know whats in the preset, but you'll either be displayed with another, different stompbox graphic, or an empty placeholder.
Either way, press either button above or below the footswitch. Repeated presses will cycle through all of the effects the Zoom has. Once you select another effect, you will now have effect 1 stacking into effect 2.
To summarise:
Hope that clears things up. it's not exactly an intuitive pedal to use. I would say that altering the order of the effects and configuring it so the footswitch turns on/off the whole preset are 'advanced' features. Try the above first!
Website || Feedback Thread || PayPal
Bear in mind some effects are DSP-hungry, so for example you probably won't be able to run 2 amp sims in the same patch - although why would you want to?
So what should happen is that as one scrolls left and right the ON light should automatically go on and off depending on whether you turned Effect X on or off the last time?
Or failing that, there is probably some youtube clips that will show you in 5 mins what would take an age for people to explain on here.
Plus I couldn't find anything on Youtube other than people running through the sounds (which I did manage myself).
But generally I find forums a better means of getting help than the alternatives. Which is why I'm here. @colourofsound's contribution is more useful than the manual because it's giving some conceptual framework to help me understand.
People don't have to respond if they think it'll take too long...
