I saw that ad and was curious enough to Google some factoids. Seller makes it sound like a big deal but some players prefer 17th fret join for higher fret accessibility.
I also prefer it to the 335 position, which is the 19th and puts the neck too far too the left - but what I really can't stand is single-cuts with it at the 16th, like the Gibson ES-135. 14th is correct for a single-cut.
Of course, this doesn't apply to Les Pauls, which do correctly have a 16th-fret neck joint - because the body is much smaller! But that doesn't make it right on a full-size hollowbody.
The odd thing is that you only have to look at the bridge and the f-holes to know what's right and what's wrong - the bridge should be level with the 'notch' in the f-holes - look at an ES-175 for illustration . So in fact, the 17th-fret Casino is probably the closest to correct of all the 33x-type guitars.
