Hey all,
I have my main board with all of my toys on but I'm currently looking into also setting up a more accessible mini board. The idea will be that I can use it for smaller gigs or quick rehearsals without the hassle of lugging a large board around...
Essentially, recommend me so good, cheap-ish (Maybe like £150 second-hand MAX), pedals in the following categories:
- Boost/EQ
- Chorus (Reaaaally like the Walrus Audio Julia but man no one wants to sell theirs, for good reason)
- Distortion (I have a Soulfood, Atlas III and DS-1 right now so none of those I guess, open to anything)
- Tuner (Looking at a Polytune 2 currently)
- Maybe delay? I'm thinking I could move my Avalanche Run across when I need to? Idk, suggestions welcome
I think 5 tops will probably do it, as I'll be setting it all up on the following plank of wood...
I think I'll probably make a separate post at some point for tips on the logistics of making this into a pedalboard.
Thanks in advance!
I’ve never found using a clip on tuner a problem for occasional gigs, although I wouldn’t want to use one all the time.
Y'know I've never actually tried a Rat? This may be a good time to have a little delve into them and see what they're about!
In terms of the type of distortion I want, can you find me a Chase Bliss Brothers for £100? Prolly not (but I mean, if you can.........). I guess I don't need anything high gain is the only parameter I'm setting myself, I'll have a look into the Black Secret tho!
Cheap as chips, sounds great
And you you could try a Deluxe Memory Man Tap Tempo 550. That’s delay and chorus in one, and also a really, really good clean boost.
What about a Thorpy warthog for the distortion. That one can do clean boost, distortion and get fuzz tones all in the one pedal. It's just if you can find any second hand ones.
https://i.imgur.com/cVvoRjW.jpg
Im not particularly after a pedal which can go fuzzy and for what I’d it for I think I could cover off with an even cheaper DS-1... possibly.
Ah my friend has a 550 and it’s superb, great recommendation.
Feedback
Its probably not a circuit for everyone but its absolutely the sound in my head!
I actually really like mine with the gain down really low, which is a sound I probably use even more than I use it cranked up.
