What sounds better - a maple neck or a free range organic roasted maple neck?
I prefer to get mine from our Farmers Market along with industrial quantities of kale and pulled pork wraps
in theory, almost all the tension in the wood is released during the process. The wood is changed on a cellular level and loses its hygroscopic tendencies...
the process can can be overdone so those cells start to break down. I assume that’s why people like Gibson stopped using the really dark bits from their original ads for roasted maple.
Instagram
So from a practical point of view, it kinda makes sense to roast Birdseye maple - (bit more stability to a less stable wood) if you want the aesthetic
..it also looks nice - nothing wrong with that!
Is any other reason needed?
'Birdseye' Maple,like Burr Walnut is taken from the root which like Briar is the most dense part.....I think
Interestingly One Luthier and 2 cabinet-makers have told me that quarter sawn is less stable than shorter grain flat -sawn
who knows/cares ?
the critical issue is the drying process and relative humidity - the optimum for construction C24 grade structural timber is 17 %
You have to wonder that if this is the seriously researched opinion of Building Technology Institute and all their testing facilities etc how can they be wrong ? or maybe, this doesn't apply to finer uses such as instruments, fine furniture etc
The guitar was very nice and resonant when put together too, but I have no idea if the roasted maple contributed to that, without comparing to an otherwise identical non-roasted one. (And bearing in mind that no two pieces of wood are ever truly identical anyway.)
For what it's worth, I hear a difference between quarter-sawn and flat-sawn necks too - it's another of those things which is not huge, but quite distinctive when you've heard a lot of examples of each. To me, quarter-sawn sounds tighter and more focused, flat-sawn sounds looser and more open. This isn't surprising when you know that a quarter-sawn neck is stiffer front-to back, the thinner dimension of the neck.
Most vintage Fender necks are flat-sawn, if it matters...
I will say having just owned a gorgeous CS LPK '62, which had a wuartersawn roasted neck... and it is superb. Very resonant and rings for ages...
Although I have seen some roasted maple necks which look too dark... the burnt toast of the guitar world.
I know some people are no doubt laughing at this, but I honestly think you can tell the difference.
Flatsawn is fine for maple, especially vintage style where some neck flex is desirable. Flatsawn mahogany is a terrible idea for a neck. Although I tend to buy flatsawn in both, because once I flip it 90 degrees and laminate it it’s effectively quartsawn anyway
the softer feeling on the roasted you had may have been misleading... it is supposed to drill easier as it’s resin content will be harder, less likely to gum up a drill bit
Instagram
may just be a light coat of oil or a rub down with wax... but all woods feel better for a bit of something
Warmoth like to focus on ease for the customer. I have worked on many of their exotics which they advertised on not needing a finish. They were all much better with a bit of extra effort
Instagram
