The big box tc’s ( Flashback 4, Alter Ego 4, Triple Delay) are easy to use and will give you three presets and fairly common. The Vox Delaylab seems to be the used bargain. The Line 6 DL4 is the daddy of this type and you still see it on pro boards but quite an old design now and has aspects not everyone likes.
Mo money and mo complexity Boss DD500, Strymon, Empress, Source Audio.
Oh and i've had the giga-delay also. DD20 or whatever. Also fantastic. Has some of the settings from the space echo.. and a couple of whacky features which sound cool.
For using multiple delays tho the TC has the edge over the Boss.. as you can cascade all three into each other, and run them in either series or parallel. With the Boss you have to scroll through the banks.
Staggering value at this price.
And I speak as someone with a Nemesis and a TC Triple (both terrific btw)
I had 2 Nova Delays die on me. When they do break they are basically unrepairable. Unless footprint is an issue then the DD20 is a much better option than the Nova Delay.
If footprint is an issue and the DD20 is too big then I'd go Line 6 M5 ahead of Nova Delay. Not having anything else at the time, I used that as a delay for a while after my second Nova Delay died. Didn't miss the Nova Delay at all.
If you can afford them, the DD500 or Timeline would both be a step above..
Other, newer, more expensive delays will do all sorts of weird and wonderful stuff that the DD-20 can't, but if what you need is basically five different DD-3s in a single box you won't go far wrong.
FWIW, I got very attached to tap tempo, and to have easy access to that and your presets on the DD-20 you'll need an external footswitch.
