Stereo amplifier, small footprint.
DarrenUKDarrenUK Frets: 0
Hi guys...
Looking for a stereo amplifier....used or new with a width of no more than 35 cm.
The only ones I have found are the teac a-h300 and a-h500.
Budget is £200.
Thank you.
  • DarrenUKDarrenUK Frets: 0
    Ideally with phono stage..
    Thank you :)
  • RockerRocker Frets: 4986
    Check TNT-audio.com, amplifiers section. There are lots of class D amplifiers, online sellers, that fit your requirements. Most will have a USB input for your computer.
    Nil Satis Nisi Optimum
    Many thanks, Rocker :)
    https://www.amptastic.com/
    excellent sound, I've got one.
    If you have more than one source, get a line level switch box from Amazon (£12 iirc), try a Pro-Ject phono stage, and you'll still get change from your £200.
  • the_jaffathe_jaffa Frets: 1798
    edited March 2018
    Have a look at Cyrus or the Musical Fidelity X-A1. They both fit the narrow requirement and there are some good deals on ebay etc.
    Add a Pro-Ject phonostage and you're good to go
