Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
If it bothers you, you can shim the sides of the pocket to make it tighter.
Do you mean normal as in a Mex Standard which is obviously the lowest end model?
The loudest and most resonant Fenders I’ve played and owned have had a gap.
My belief is that the rigidity of the neck, it being screwed tight correctly, and the resonances of the neck and body working together is a far greater factor than some bits of wood passively touching the sides of some other bits of wood.
Re: tightness - If there is any gap, even a hair’s width, it’s essentially the same as a large gap, as the vibrations can’t ‘jump’ the air between. If you look very closely a lot of ‘tight’ necks don’t perfectly touch, they just look like they do. Unless you can lift the guitar by the neck and have the body still stay attached without any screws in then it’s not that tight really.
TBH I would have thought with CNC cutting nowadays they could make a better fit on bolt on guitars without trying too hard.
If this was Gibson they'd be getting a right tanning.
I was reading a review in Guitar Player the other week, I think it was a Hahn guitar - they said he always makes his guitars so that they can be picked up without the screws in place.
But I agree with you, a gap is a gap. I think it should be tight enough to prevent significant movement, with no obvious visible gap, but loose enough that you can fit or remove the neck without chipping bits of paint off the edges of the pocket. Most necks which look tight, if you hold them up to a light and angle them right, you can see a hair's breadth of daylight through the gap.
Sometimes when I've tried to fit a really tight-fitting neck it's made alarming creaking noises as the screws pull it into the neck pocket - presumably because it's actually tighter at some points than others. That suggests that once in place it's under some kind of tension - in addition to the tension from the strings - which doesn't seem like a desirable thing to me.
what most dont point out is they often have to be lightly sanded after that pic. If it’s a set neck, once you add glue it can actually get stuck halfway in if it’s too tight. On a bolt on, you usually want to add a bit of finish which can change the perfect fit . Or wood can just move a bit... yeah, you can crack a body if it’s too tight
the other one that used to be popular is a luthier standing on a neck to show how strong it is. You can do this with almost any non-Gibson neck. Certainly any fender style.
all makes for good pics though
Instagram
There's a clip on the Ruokangas site of him standing on a neck with a tiltback headstock, I think it's a sort of scarf joint done in their particular fashion.
To be fair he looks a bit sheepish and says he wouldn't do it again.
Instagram
