I have not weighed many fender styles from blank to finished body so I could be way off. @GSPBASSES will know
Instagram
http://a65.tinypic.com/2cp8ffs.jpg
for sale if you want it!
http://www.thefretboard.co.uk/discussion/127362/fs-two-piece-swamp-ash-strat-body-50#latest
I was going to choose the 3 6 kg blanks anyway, I don't want feather light just not heavy
(formerly customkits)
http://a68.tinypic.com/wkp6qw.jpg
The bodies you got, are they to spec?
The necks will be vintage spec ones
I really like an aged sonic blue for a slab board strat but can easily change my mind at any point
• Youtube - https://www.youtube.com/@Goldeneraguitars
Having said that.. I’m sitting here with a rather nice 3lb 7oz ash tele body
I just couldn't be bothered to make them i've got enough to do and the 2 I got sent to finish were nice so ordered them
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I could tell you all about Lp weights with a body and parts etc, my 5.2lb semi chambered goldtop body weighed 7.8 finished, that's wraptail and p90's
For me a strat or tele is nice between 7-8lbs
My all limba dc junior is about 7lb, I like that weight
If you're buying planks of wood or body blanks it's quite easy to calculate the approximate finish weight of the Strat or a Tele. All you need is a measure, calculator and a pair of digital scales. I know we are meant to be metric now, but most people want the weights in pounds and ounces.
About two weeks ago I had to make 2 Strat's and a Tele, I still have the calculations I used to work out the finish weights.
The formula for doing this is, length X width X thickness to give you the cubic inches there are in the piece of wood, the weight of the wood is then divided by the cubic inch measurement. This will give you the weight per cubic inch of the wood. The cubic inch is then multiplied by how many cubic inches there are in the body you're going to make.
These are some of the calculations I done a few weeks ago.
Tele
14.75 X 18.5 X 1.75 = 447.5 cubic inches.
The weight of the wood 138 oz
138 / 447.5 = .3 oz
.3 oz X 265* = 79.5 oz ( just under 5lb)
The finished body weighed 4lb 14oz , 2.21 Kg
Strat
33.5 X 7.25 X 1.9 = 489 cubic inches
The weight of the wood 133 oz
133 / 489 = .27 oz
.27 oz X 280** = 75.6 oz (4lb 15oz)
The finished body weighed 4lb 14oz 2.21 Kg
Start
33.5 X 8.5 X 1.75 = 498 cubic inches
The weight of the wood 128 oz
128 / 498 = .26
.26oz X 280** = 72 oz (4lb 12oz)
The finished body weighed 4lb 10oz 2.09 Kg
* 265 is the approximate number of cubic inches in aTele body, this is fully routed
**280 is the approximate number of cubic inches in a Strat body, this is fully routed and shaped.
This formula is obviously only approximate, but it does give you a ballpark figure of what a piece of wood is going weigh when it's turned into a body. If you're buying rough-cut wood the formula can be way out, the closer the measurements are to the final size of the guitar, the more accurate the formula will be.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
One thing that fascinates me is that a Strat has a greater cubic capacity than a Tele!!!! And I always regarded a Tele as 'just a great big slab of wood' lol
What makes it so suprising is that you would have thought that the trem cavity, arm relief and back scoop of a Strat would make a tangible reduction against the more basic shape of the Tele. Presumably, the Strat is longer and wider?
Instagram
