Fret third, distance between string and first?
robgilmorobgilmo Frets: 3681
On a Strat, is there an ideal distance? Mine is 0.3 mm.
  • WezVWezV Frets: 16895
    0.000000000000000000000000000000000000000000000123
  • robgilmorobgilmo Frets: 3681
    feet?
    robgilmo said:
    feet?
    2
    b or not 2 b ?
  • amarok1971amarok1971 Frets: 338
    Graphtech say 0.25 on E and 0.15 on e
    I am down to that now, but on my snark when I fret an f on the e string I am two bars sharp, that shouldn't matter too much should it?
    Unless it's an incredibly precise tuner I wouldn't be happy with it being two bars sharp.
    As far as I know, the ideal distance is one file motion away from it actually touching the fret and it looks to the naked eye like it's touching but if you touch it, it makes a pingy noise indicating it is't already touching it.
    I've just measures a couple of my prs... 1 is at 0.1 on both e's and the other is at 0.15. Neither fret sharp at the first fret
  • FelineGuitarsFelineGuitars Frets: 11694
    Gap should be such that you can only JUST detect a gap- sort of rizla paper to writing paper gap
    If that still fails (and the strings are FRESH) then consider an Earvana nut
  • BloodEagleBloodEagle Frets: 5320
    Surely with such small gaps you get all kinds of open string buzz?
    You shouldn't, unfretted you rely on bridge action.Im having a wine break, will start back in  a bit, but its getting there!
    if you can put a capo on at the first fret and play cleanly
    then in theory you should be able to get away with the same height over the first fret from the nut as you were having over the second fret when capoed at the first..almost like a guitar with a zero fret
  • ICBMICBM Frets: 72927
    Aim for about 0.05mm on the top E string up to 0.1mm for the low E - or Rizla paper, as FelineGuitars said.
    It doesn't have to be exact, but the gap should be much smaller than the string diameter. 0.3mm is slightly larger than the top E diameter.
    PRS use a slightly forward compensated nut position which also helps.
  • HAL9000HAL9000 Frets: 9808
    Don't forget that fretted notes might be sharp due to technique rather than the intonation being out. It's not unheard off to be holding down a string and bending it slightly at the same time.
    Also, stupid question but I'm assuming that the intonation at the twelfth fret has already been sorted?
    Its the nut height, its still way too high, I stopped for a wine break and didnt get back to it, damn wine! I should finish it tonight.
  • crunchmancrunchman Frets: 11503
    Wasn't that patented in the 80's?  The patent should have expired by now.  I don't understand why other manufacturers don't do the same.
  • richardhomerrichardhomer Frets: 24863
    As @ICBM said, PRS move the nut closer to the first fret to ‘sweeten’ the tuning over the first few frets - I believe the Buzz Feiten system does the same.
    I wouldn’t worry too much about how notes at the first fret read on a tuner - the real issue is if they actually sound ‘out’. Owing to the physics of guitars, not every note will be ‘in’ on a tuner - the whole thing is a compromise.
    Buzz Feiten did patent it, as part of his ‘system’ - but that shouldn’t have been allowed since other makers, including PRS and Hamer, were already doing it.
    The odd thing is that one of the most ‘in tune’ guitars I’ve ever heard was my Rickenbacker 660/12, which does not have a compensated nut position. But it does have the ability to set the neck very straight and the action very low, since you don’t tend to bend strings on a 12-string.
    I also used rolled-wound strings on it, which seem to intonate very evenly - flatwounds even more so. It intonated to within +/- 1 cent on every string at every fret, except for a couple of the thickest strings at the very last fret.
    For what it’s worth, the more even intonation of flatwounds is why 50s Les Pauls have the bridge set straighter on the body than modern ones - that’s what they were designed for.
    At the end of the day it’s all a complex combination of factors - but it’s part of why guitars sound like guitars. If you eliminate them all and produce perfect intonation it starts to sound too much like a sampled guitar rather than a real one.
    Thos is true, and this has small vintage type frets so it wont get any worse unless I press unusually hard, I have been playing it at every step between reducing the gap and it sounds Ok.
  • guitars4youguitars4you Frets: 14654
    I knew that but forgot about it - almost a kept secret - they make no fuss about it - but you do generally find excellent intonation on a PRS
