FS/FT: Blackstar HT60 soloist 1x12 combo £350
This amp can be set to work as a two channel amp with an independent boost circuit for each channel, or it can be set to work as a three channel amp. Very versatile feature list including the speaker emulated line out for direct recording, this amp is loud enough to give you all the clean headroom you will ever need at any gig while still being small and portable enough to transport easily. Only marks are the two small nicks in the tolex at the bottom. Just been serviced by Root Two so it is in as-new working condition and has an absolutely brand new set of matched tung sol EL34's fitted which are far superior to the stock ones. Comes with the additional FS-6 footswitch. Collection from Washington Tyne and Wear UK or meet within reason.
https://imgur.com/a/nweyA
