Solderless wiring sets - question
MattBansheeMattBanshee Frets: 1498
Just got a solderless wiring loom upgrade, which has little screw terminals for pickup wires. I also have a new pickup set. Question is; should I tin the pickup wire ends with solder before using the screw terminal, or will they be fine just twisting the strands? Thanks :-)
  • ICBMICBM Frets: 72429
    Surely if you have the tools and the skills to tin the wires, it would be better just to do the job with solder connections in the first place?
  • MattBansheeMattBanshee Frets: 1498
    My skills are limited, and the wiring loom was a significant upgrade with much better pots, cap, jack etc, the solderless connection was a bonus feature.
  • SteveRobinsonSteveRobinson Frets: 7038
    A customer asked me to help when he couldn't work out why the solderless harness he'd bought gave no output, even with the pickups connected in the little green block:
  • SporkySporky Frets: 28421
    Never mix soldered and compression. Either just twist them, or put bootlace ferrules on.
  • FunkfingersFunkfingers Frets: 14472
    Which one? The EMG157c Buss board, the Duncan Liberator, their Blackouts Pre-Amp device or some other system?
    A nice man made it for me with CTS pots and a NOS cap (there is some solder, but not on my part and the pickups/ground are on a terminal block).
