Im not a fan of telecasters but they sound godly with that set.
@impmann owns a set/single pickup and likes teles, he can probably steer you right
Check out Montys Pickups too
• Youtube - https://www.youtube.com/@Goldeneraguitars
The Seymour Duncan Broadcaster is also amazing.
I have both. I love them equally.
I had a set of Creamery Tele pickups that were OK but a little harsh to my ears. I couldn't tell you which set because I bought the guitar with them fitted (I'm sure they would have sounded better in a different guitar) - I sold them and installed a set of Oil City Whapping Wharfs, which were much nicer IMHO. I've had a few sets of Ash's Tele pickups and each set has been superb - I don't think he makes a 'bad' Tele pickup but they are definitely different flavours.
Another to consider is the Alegree Cirrostratus - very nice, well balanced set. Definitely in my top 5 fave Tele pickup sets. I especially like these in Ash bodied Teles.
Now here's the thing...
Yes, the early Tele pickup was wound hotter (slightly) and that gives the mids a bit more of a push, but this can be at the expense of treble clarity in some 'Broadcaster" sets. For example, I detest the Fender set of that name for exactly that reason - to get any sparkle from them you have to have the pickups too close. They also have confused mids compared to the Seymour Duncan and Mojo units of the same name. You may be surprised by the more full range sound of the later pickups - albeit they normally have a lower resistance (7.5k on average). In the right guitar these things sound HUGE.
Personally - I'd speak to the winders themselves (Ash, Marc at Mojo, Alex at Alegree etc) to discuss what sort of sound you are trying to achieve in that particular guitar. We live in charmed times for handmade pickups right now - especially so because you can talk to the actual people that will wind them to suit *you*.
It's a great pickup. I love mine.
What they do have ... as a result of the thinner wire, is more mids, and less treble, added to this they use alnico 3 rather than alnico 5 as later ones used. Alnico 3 is the lowest magnetic power alnico, and comes with a sort of natural compression, added to a very low string pull.
Ok I accept part of that. However, more upper mids actually make the early type Pickup appear louder - in certain circumstances.
The later pickup has more top and a scooping of the upper mids which gives it a lot of twang and zing. But give it a driven amp, you need to dial the treble down a touch or it can be too much (especially in an Ash body). With a Broadcaster type, that harsh top end doesn’t need attenuating and appears louder - hence the concept of them being hotter.
Before the prices went nuts, I had a lap steel pickup from 49 that I bought for 65 dollars... the mids off that pickup would drive an AC30 *beautifully* and it was a phat sound. The perception of loudness from it was far greater than the Fender 1960s US reissue pickup it replaced. I sold the 49 for £300 and thought I was doing well...
Interestingly, some pickup makers have a DC resistance of significantly more than 9k for their ‘Broadcaster’ style pickups.... perhaps, as with many things to do with vintage guitars, there was a degree of randomness in the number of turns crammed onto some old pickups and that has translated into hotter pickups from some makers.
Ive got a set of fender broadcasters which im really pleased with but havent tried much else 'broadcaster' wise.Very tempted with a mojo broadcaster set.
The Early Tele pickup is actually one of my favorite Fender designs ... and to my mind suits many rock styles better than the later type.
As an aside, this sort of pickup shouldn't be referred to as a 'Broadcaster' pickup ... as it pre-dates the Broadcaster and was first fitted to the Esquire ... the first Fender solid body 'Spanish' guitar. That's why my version is known as the Fortyniner ... not Broadcaster.
