Jaguar bridge p'up
wrinkleygitwrinkleygit Frets: 261
having bonded with my mim jag, while I love the sounds available from the stock neck p'up I find the single coil in the bridge pos a bit lacklustre, anyone tried a s/coil sized humbucker such as a JB jnr or similar & are there any issues fitting one to a jag apart from losing the chrome claw
    I'd personally get something wound to taste by mojo pickups.
    If you email him and tell him what you are after he will sort you out
  • jimmyguitarjimmyguitar Frets: 2474
    Have you tried raising it more? I put a bigger bit of foam under mine and now the bridge pickup sounds way better.
  • wrinkleygitwrinkleygit Frets: 261
    Thanks jimmy I have tried that, also changed the function of the strangle switch to ser/para which made quite a difference as well but not quite enough
  • FunkfingersFunkfingers Frets: 14569
    mim jag ... love the sounds available from the stock neck p'up
    IMO, the neck pickup on Fender MIJ/CIJ/MIM Jags is what the bridge pickup ought to sound like.
    the single coil in the bridge pos - a bit lacklustre
    It is supposed to be. The guitar was designed to be used with what we now consider Medium gauge strings.
    Talk to the hand HarrySeven. When it comes to beefing up budget Jaguars, he is a repeat offender.
    Good idea. Some of the pickup makers on this forum produce P90-in-a-Stratocaster-size pickups. It would be no great hardship to build one to fit the Jaguar pickup cavity. One of those might answer the brief. Its adjustable polepiece screws would improve string-to-string volume balance.
    A decent Jaguar pickup has balls and grit and all the things you want. You dont need a strat pickup, a p-90 or any other pickup.
    Clearly, the majority of Fender and Squier Jaguar pickups are not decent. :)
  • impmannimpmann Frets: 12672
    No they aren’t. And if you compare them to the pickups they are supposedly copying, it’s chalk and cheese. Those awful Duncan Designed pickups are terrible - genuinely - but they are better than the MIJ/MIM stuff and not far off the US made junk.
    That is why we have proper pickup winders and ALL the good ones are busy right now.
    TBH, I’m a Fender player but my ears tell me that other people are making far better Fender design pickups than they are right now.
  • JD50JD50 Frets: 660
    Perhaps look out for a 2nd hand AVRI pickup?
    On guitar, no they're not. I have no grumbles with the bass pickups, however I am not a true bassist.
    Impmann covered it pretty well above
  • TrotterTrotter Frets: 516
    I had a Seymour Duncan 1/4 pounder for jag in the bridge of mine for a while. Sounded great but I have numerous humbucker guitars that cover that angle. In the end I opted for a pair of Lollar for jaguar pickups which are just so very sweet when compared with the stock Japanese pickups that were in mine. It is now a very usable studio toy which brings something to the table that none of my other guitars can. I guess it's the difference of enhancing the jag sound, as opposed to fundamentally changing it.
    Not difficult!
    Only if you are brassic. (See impmann's post above.) The stock pickups from my AVRI '62 went to somebody on this forum. I never want to see them again. By some accounts, the AVRI '65 pickups are little better.
    Trotter said:
    Lollar
    Noice. I opted for Seymour Duncan Antiquity 1 and 2. (A2 magnets for the neck position. A5 magnets for the bridge.)
    You say enhancing. I say restoring.
    Precisely, Watson. I tolerate the clunky ride because nothing else can produce some of those sounds.
