Case recommendations for flying with budget airlines.
Rowby1Rowby1 Frets: 1280
Looks like I’m going to be doing some stuff that involves flying in a few months.
I’ve flown with guitars before (and had two ABS cases wrecked by baggage handlers, guitar survived both times though). Just wondered if there was anything better than the standard ABS type cases around now?
It’ll probably be my Tele that’ll be making the trips as it’s somewhat more robust than my other guitars.
    For carry-on Mono, for hold, Hiscox
    Feedback
  • telehacktelehack Frets: 93
    I have a radical suggestion - If you're checking a suitcase, unbolt the neck, wrap both the neck and body in padding/clothes. Re-assemble at the other end...
  • ICBMICBM Frets: 72485
    Hiscox, or what telehack said.
  • Rowby1Rowby1 Frets: 1280
    edited April 2018
    Thanks chaps, Hiscox it is then. Wasn’t planning on a suitcase as well so the dismantle idea won’t be an option.
  • StuartMac290StuartMac290 Frets: 1468
    Hiscox Pro Series
    Hiscox Pro Series
    Just what I’ve ordered
  • John_PJohn_P Frets: 2750
    Have a look at Scott Dixon cases.  I use the triple for most gigs are they built like a tank but still very light.
