That would be tricky to do, as pedals draw some current when off. You could feasibly trigger an led when the current draw exceeds a predetermined level, but that level would be different to every model of pedal.
http://doktorsewage.com/vintage-mxr-phase-90-sees-the-light/
R.
Eqd Speaker Cranker clone
Someone like bright onion will probably have one suitable if you have space on your board.
The loop switcher is definitely an idea.
I've got a GigRig Loopy 2 sat doing not an awful lot, if you want to go down that route.
http://i.imgur.com/UMuVQjY.jpg
Try the Lehle Little Lehle II, that is about as small as it gets.
I did dozens of them back in the 80s so I may be a bit blasé about this though .
I would also true-bypass it at the same time because the Phase 90 is notoriously tone-sucking with the original SPDT switching. If 3PDTs had been available back then I would have done that too...
