I bought a cheap ‘Ferm’ Dremel-alike last year on impulse and was surprised at how much use it’s had since. However, I’m now in need of a right-angle chuck attachment and I can only find genuine Dremel ones or Dremel compatible ones. Ferm don’t make one for mine and I haven’t been able to establish whether the big collar thread is the same on mine as the official Dremel so I could use one meant for a Dremel.
I’ve discovered that the Dremel thread is a 3/4” UN12. The external diameter of the threaded end of mine is 18mm. I have no idea if that means they will fit or not!
My question(s) are; do any thread experts know if a 3/4” UN12 nut will fit on an 18mm shaft and, as I suspect it may not, do you have any advice on which Dremel to get to replace my Ferm as there seems to be several models.
Ta!
3/4" is near enough 18mm, but the thread (UN) is going to be imperial.
That said, I bought a third-party flexible shaft (no laughing at the back) which fits both my cheapy Silverline knockoff as well as my kosher Dremel. The only problem I found is that the thread on the Silverline wore out as the plastic casing wasn't made out of plastic after all, but Dairylea. Whether that had anything to do with differing threads I don't know but I never forced anything that wouldn't obviously fit.
I bought the proper Dremel in B&Q - it was the cheapest one I could find. I needed it to fit into the Dremel router base as that uses the chuck thread too, and the Silverline was obviously done for. I already had the router base and couldn't be arsed waiting to buy the drill online, so you could no doubt find it cheaper...
https://www.diy.com/multi-tools-hobby-tools/dremel-230v-130w-corded-multi-tool-3000/203773_BQ.prd
Hah yeah, in the main I'd agree. I have the odd one of theirs that's OK - the aforementioned Dremel-a-like works fine if you don't need attachments (i.e. just as a drill). I also have a pillar drill of theirs that I've used for years for all sorts and has surprisingly little runout.
But no - I wouldn't buy anything from them that I needed to get hard use from or that I needed to be bob-on accurate. Assume their stuff is going to be utter dreck with the odd pleasant revelation and you won't go far wrong
https://twitter.com/spark240
Reddit r/newmusicreview
I've got a Black and Decker dremel-a-like which does have the same thread, and was noticeably cheaper at the time I bought it.
Which might well help Emp, as the flexi shaft thing I have is made by Black and Decker and fitted both the Silverline and the Dremel.
I've a sneaking suspicion that these things are fairly universal but wouldn't want to commit.
If the 12 in your 3/4 thread is teeth per inch, from what I can find 18 mm is 10.2 teeth per inch, i.e. a coarser thread that isn't compatible.
then I got a dremel.
Then my Dad got a dremel kit with most of the attachments, but never used it.. I got a free upgrade
Instagram
Mate of mine lent me his cordless Dremel a while ago. What a revelation that was, very impressed. OK, I broke it while I was using it, but as he'd bought a new one, it mattered not.
But when I get another one, it'll be cordless only. So much nicer to use. Dremel's are overpriced, though.
Nil Satis Nisi Optimum
I've decided to buy a proper Dremel. B&Q have the 3000 model for £45, so I'm off up there in a minute.
