Hello.
Is anyone using the boss FV30H?
If so do you like it?
What are the pros and cons?
Reason I ask is, I've had a VPJR for ever. Recently though it's started playing up. Its not completely silent at heel and it's not going all the way to the to toe position it seems to rock back about 1/2 a centimetre. I've got a replacement string kit for it so hopefully that'll cure it, but I've been thinking about replacing it as it's massive it and takes up quite a bit of space on my board.
The boss FV30 looks to be the best choice as it's a lot smaller than the vpjr but I'm worried I won't get on with it as I'm so used to the vpjr.
Has anyone tried both and if so which one did you prefer?
Or is there another volume pedal that's smaller than a VPJR I should be checking out?
Ta.
