In a spirit of exploration, a few weeks ago I wired up a LP with 0.0022 caps rather than 0.022
This was obviously entirely intentional and not a symptom of the idiocy which has followed me around like a shaggy dog since I were but a child
Today (..also in the spirit of exploration you understand) I put 0.022 caps into the same guitar
As expected, I get a lot more roll off when I roll down the tones, but I'm also pretty certain that the tone on 10 is also brighter (and better for it)
Is there some 'capacitance in circuit changing resonant peak type thing' going on here? ..can anyone explain it in language that someone who puts the wrong caps into a guitar can understand?
You can actually test this very simply by fitting a small SPDT switch in the back of the guitar so you can select the two different caps on the fly. If you flip back and forth with the tone control turned up full you will hear a small difference.
..trust your ears they say - phaaa!
It's your brain that's the devious bugger .
This is why I like to set up direct-switching tests, comparing two sounds instantly on the fly and while the sound is actually continuous - that way, you are able to hear if something changes even slightly (or not) and the brain doesn't get as much of a chance to interfere...
https://www.premierguitar.com/articles/23145-cap-and-pot-trade
Falbo used to work for Seymour Duncan Incorporated. Now he is a consultant with Fishman and a luthier in his own right. He might know what he is talking about.
