FS: Pickups, just David White left
KKJaleKKJale Frets: 982
edited April 2020 in Parts £
DiMarzio DP181 Fast Track 1, black, box and paper, wire approx 24cm, £35 - sold
DiMarzio DP182 Fast Track 2, black, box and paper, wire approx 17cm, £30
Kent Armstrong STV-1/R set, reverse wound middle. No covers but come with screws and springs. Cloth wire. Plenty of length save for the middle one which needs splicing. RRP £150… £45 - sold
Entwistle-White pickups, designed by Alan Entwistle in the early 90s and wound by the late David White of "Old Glory" Strat pickups fame. These are single-coils with laminated silicon/iron blade magnets. They came on the high-end Hohners at the time, hence the covers marked 'Entwistle-White' and 'Hohner' (see http://www.entwistlepickups.com/about.php?fllstry=y   for more). Two have white covers, one has a black cover and larger bar magnets and more winds. There is one box labelled "LGX 600" which likely goes with the black one. Lots of wire length. Tricky to price as they're pretty obscure and the maker is a bit of a legend. Asking £40 each, but talk to me....
Fast Track 1
https://i.imgur.com/SoB5TUA.jpg
Fast Track 2
https://i.imgur.com/2tKdHgO.jpg
Kent Armstrongs
Entwistle-Whites
https://i.imgur.com/gmarDa5.jpg
https://i.imgur.com/bHdq32i.jpg
  • KKJaleKKJale Frets: 982
    Magnetic bump.
    Bump!
  • flyingvflyingv Frets: 555
    Pm’d
  • lovestrat74lovestrat74 Frets: 2529
    Are the Kent Armstrong pups still available? Do you know the outputs?
    Still available but the box they're in is somewhat slightly mislaid, as I discovered when searching out some Rio Grandes for somebody last night... along with two Lollar Imperials and three Lollar Blackfaces. FML
    I'll have a proper hunt when I can!
    @lovestrat74  Found. I make them 6.12, 6.13 and 6.20.
    Bear in mind two, possibly three leads are short and need splicing, hence cheapnizz.
    Ooh quite punchy then! PM me if you can do a deal with these and your Cadillac strap - if still for sale ;)
  • alvynmcqalvynmcq Frets: 11
    PM sent
