In my bid to cut down on my amp stable I’m putting this lovely little fella up for sale/trade.
Its a hand wired Marshall style EL34 powered small head with a few additions.
Heres the original thread from our own 4114Effects:
http://www.thefretboard.co.uk/discussion/111909/(Including some interim pics)
Its cathode biased so doesn’t need any faffing around when changing valves.
Treble, middle, bass, gain and master volume. It also has a second footswitchable master volume you can use to boost it.
The three toggle switches on the front are the Friedman C45 mod, three position gain switch and a fat switch.
8ohm and 16ohm outputs.
W50cm x D20cm x H20cm
It also has a matching active footswitch Dan kindly made for me.
One thing to note, the fx loop appears to be a high level one similar to the Soldano SLO, it will distort with guitar level pedals.
I’ve not had any issues going straight into the front end but if a transparent fx loop is important to you and your sound this may not be for you.
I landed two guitarist jobs after auditioning with this Amp and a small pedalboard.
It does the modded Marshall thing all day long and is really compact but powerful. I always take this and a zilla dinky with me to gigs as a small backup
It takes pedals into the front end really well including drive and modulation effects.
I took this to the Hudderfield jam and it help its own next to the other amps there.
Its in excellent condition, the dymo labels will just peel off, I just put them on to remind myself what they all do!
(I’ll put my own pics up as and when tinypic comes back online)
open to trades, based in York but happy to meet.
http://i65.tinypic.com/b5pbiv.jpghttp://i63.tinypic.com/330hgdi.jpghttp://i68.tinypic.com/23i86sn.jpghttp://i67.tinypic.com/2e55zqw.jpghttp://i64.tinypic.com/33nl2fk.jpgInternals:
http://i65.tinypic.com/ohptds.jpgHere it is perched on top of a Zilla Dinky cab and full size Jubilee and 212 for some size perspective:
http://i63.tinypic.com/2s9p2iw.jpghttp://i63.tinypic.com/168voxs.jpg
