This is an outstanding piece of equipment allowing you to use two valve amps into one cab as well as having the option to switch between them either with the pedal itself or remotely
Over £200 new, this one is in perfect condition with the original power supply and will be securely packaged - non-original box. I now have just one amp head so I haven't been using it. FREE DELIVERY
https://i.imgur.com/Z0AFbeO.jpg
https://i.imgur.com/dk2PBuy.jpg
https://i.imgur.com/G0waXNH.jpg
https://i.imgur.com/4gYW2nW.jpg
https://i.imgur.com/qGUfacC.jpg
https://i.imgur.com/Hp9JxVF.jpg
https://i.imgur.com/6FJfI9b.jpg
https://i.imgur.com/nFbe5sc.jpg
https://i.imgur.com/dl3LZzf.jpg
https://i.imgur.com/14uc7EM.jpg
https://i.imgur.com/7iMKwVr.jpg
"The Radial Headbone is an advanced amplifier switching device that allows two different guitar amp heads to be used with a single speaker cabinet. With the Headbone, one head could be used for rhythm while a second head could be used for soloing. With 100% discreet Class-A circuitry and choice of either buffered or un-buffered inputs, the Headbone will be of particular interest for players that demand the utmost in tonal performance.
The Headbone's internal switching comprises a sequence of relays, photocells, and load resistors, all of which are controlled via a digitally programmed chip. Hit the footswitch and the Headbone toggles the guitar signal from one amp to the other, disconnects the speaker and diverts the signal to a load resister, reconnects the speaker to the second head and turns on the guitar, all in quick succession. The Headbone features SafeMode™ whereby even when power is disconnected; the Headbone will automatically default to 'head-1 to cabinet' status, ensuring a constant load on the amplifier.
Headbone comes equipped with Slingshot™, an easy-to-use switching system that uses any standard footswitch to toggle the Headbone's status remotely, from wherever the footswitch is located. Slingshot lets you keep the amp-to-speaker cables short and efficient and opens up new switching possibilities too."
Switch 2 heads using one speaker cabinet
Slingshot remote control with any footswitch
Digital micro-controlled relays for fail-safe switching
Choice of direct or buffered input
Eqd Speaker Cranker clone
Steve
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
