which drive to complement..
thomasw88thomasw88 Frets: 2335
just bought a liquid sunshine mk3 and used it at last nights gig.
My order of drives last night was modded SD1,  liquid sunshine and then an old rat., going into a wienbrock gringo (fender 5e3 type amp)
I really liked the Liquid sunshine but I wanted a bit more gain for it for solo's , but the the SD1 didn't quite work in that context, ( as  and sounded a bit gnarly (crap explanation I know!).
 I could swap them over of course but I was wanting  the LIquid sunshine sound rather than the SD1.
So question is more what would work well going into the liquid sunshine? I'm thinking possible a klon centaur type pedal?  Tumnus or something like that??
So suggestions please!  Not wild on clean boosts or eq pedals
    Nobels odr-1 or odr-s
  • soma1975soma1975 Frets: 6829
    A Greer Lightspeed stacked with anything sounds mega.
  • Winny_PoohWinny_Pooh Frets: 7802
    edited June 2018
    An odr-1 behind the LS smooths and fattens, especially if you switch to the bridge pickup. Tubby in the middle or neck position though.
    If you want a kinda neutral "more" pedal the Timmy will work well.
    Which mod have you got/used? I did my own which basically was removed a diode or something (I can't remember it was years ago). It removed the "blanket over the speaker" sound.
