BM Mammoth - characterful old 1970s plywood acoustic. If it plays well and has no structural issues - £150
Tanglewood - functional modern electro-acoustic - £150
Richwoods and Ibanez Artcore - cheap archtops - £150 each
Epiphone ES-175 Premium (not Swingster) - better-quality archtop - £400
Epiphone Casino - older version with the less vintage-correct 17th-fret neck joint - £300
Gretsch Electromatic 5120 - older version with the wrong-size pickups - £300
Ryder Tele - cheap not boutique! - £100
Fender Hotrod Deluxe - there are four versions, but all very similar. II is the most common - £350
Marshall AVT50 - average-sounding and known to be unreliable - £100
Squier Silver Series Strat - quite nice, but not as much as a JV - £250
Fender USA Standard Strat (1997) - 'blockboard body' era, so not worth quite as much as an older or newer one - £500
Give or take £50 on most of them probably, and don't take it as absolute gospel!
I have asked for some more specific pics of serial / model numbers where there are none (inside the acoustic / archtops etc).
I have also asked if they come with hard cases etc.
Any other opinions more than welcome.
the Epiphones …
https://i.imgur.com/PcMUFVe.jpg
https://i.imgur.com/JATJhAQ.jpg
The blonde Richwood back and front
https://i.imgur.com/7KjhGZM.jpg
https://i.imgur.com/YCPYZ2g.jpg
the other Richwood (I think)
https://i.imgur.com/Xo6Fg7w.jpg
the Gretsch
https://i.imgur.com/Vw0LE81.jpg
the BM Mammoth turns out to be MIJ
https://i.imgur.com/n69g9hw.jpg
The 'Sue Ryder charity shop tele'
https://i.imgur.com/wU3xaDV.jpg
This site: http://www.guitardaterproject.org/epiphone.aspx will tell you about the Epiphone - where and when built.
Nonetheless, if you offered me the pick of any of these guitars, that's the one I would choose. It's the most interesting and characterful, even if not the best quality,
Second choice would be the Epiphone Casino, I also prefer the 'less vintage correct' neck joint over the 'correct' one.
@ICBM Interesting take on the 'quirky' being desirable and I need to know more about that 'period correct' detail on the Epiphone … hollows / archtops / jazzers etc are not in my area of knowledge at all … save for a little knowledge about semi-hollow staples like 335 etc.
@impmann Point noted on the Squier and the Fender …
Another comment I have no knowledge of is the 'blockboard' …
turns out they do Ibanez too: http://www.guitardaterproject.org/ibanez.aspx
This is the 'correct' version, you can see that the neck is set noticeably deeper into the body. Look at the gap between the pickguard and the cutaway for one of the most obvious clues.
http://images.epiphone.com.s3.amazonaws.com/Products/Archtop/Casino/Gallery/POP_Casino-NA.jpg
As far as I know all the US Standard bodies other than the Ash special editions were, regardless of finish. It's only really obvious on the sunburst Strats and basses though, because the dark part of the burst follows the edge of the belly contour on the back instead of the edge of the body, to hide the join. On the front, the veneer was curved to fit the body before finishing so there is no visible join. (And obviously on the Teles there is no contouring.)
I agree that there's probably little or no tone difference, but it does make this era of US Stds (roughly 1994-2000) less desirable.
All these things are probably in the realms of Shut Up And Play Yer Guitar I know , but they do affect the values.
