I have a SSS Suhr classic pro with the superswitch 5 way toggle. I am fitting a thornbucker to the bridge which I intend to add parallel/series wiring to via a push/pull tone pot.
I would like to add a 'Neck on' switch to the other tone pot via a Push/pull toggle. Is this possible?
Would anyone be able to explain how to wire this?
I have a full wiring diagram from Suhr for the entire circuit as described (but without the push/pull neck on option). I'm not allowed to share the schematic in public so if anyone can help me, would you please either post a description of what to do or PM me and i'll let you see the schematic to help you explain.
Many thanks to the wisdomous folks here and the help that is sure to follow! :-)
(this is bridge on with push pull)
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
https://www.premierguitar.com/ext/resources/archives/issue/features/images/200810_sevensoundstrat_3.gif
https://www.thefretboard.co.uk/discussion/57776/handsomerik/p1
